a computer has no concept of what work is...so who cares!BigWill wrote:So, let me see if I understand you correctly.Why cause the computer to have to work harder to correct something that wouldn't happen if you were using the right octane grade.
problem is you really never know for sure what you are getting when you fuel up...even with so-called premium. i'll give you an example...i recently filled up my g with high octane at a local gas station. the next day i noticed it wasn't running quite right for the first 30 seconds after a cold start. and it seemed really down on power. low and behold the local transporter had put diesel in the wrong underground take at the gas station! luckily it didn't harm my car...just caused a service engine soon light.Q45tech wrote:I buy 93-91 octane [without ethanol] to get the higher level of detergents to help kept the internals clean...[premiums usually have more detergents]...............the octane is a bonus especially in Summer.
You cannot lump all refiners together and each hours production will be different, hoever much gets dumped into a family holding tank at the tank farm so the good gets worse and the bad gets better.........sometimes.
until someone can actually show me a 3.5l g35 motor that suffered from premature failure due to using 87 octane...i'll still say that an automatic g35 coupe or sedan can certainly live a long, happy life on 87. but to each his own...BigWill wrote:To answer the author's original question, no, you don't HAVE to use the recommended gasoline, no you don't HAVE to do anything that is outlined in the manual. Will it cause damage to your engine? The experienced techs here seem to feel that it will, long term. Do you believe it, or even care? That is the more important question to ask yourself.
Ok I hope I don't start a huge debate about this but I just wanted to state one thing about the underlined portion above. Our cars or at least the 03 coupe I know has a 10.5 to 1 compression ratio. Now granted we have this smart computer that retards our timing should we have to put less than 91+ octane in it. On the same token however have you ever driven something with that high of compression without the computer on 87 octane ? I have. My two motorcycles a 1990 FZR1000 and it's little brother the FZR600 which have the same compression ratio and no computer will run absolutely like crap on 87 octane sputtering and popping and overall barely running coupled with dramatic power loss. So what happens if we're running 87 octane in our cars and the computer has a problem effectively eliminating the timing control. Now I'm not 100% positive but I would assume there is a preset default it will fall to should it have a problem like that and if I were to guess I would say that it would default to factory specs with recommended timing. That would mean at this stage there could be possible damage to the engine from knocking/or pinging. Just my 2 cents.redhed wrote:
problem is you really never know for sure what you are getting when you fuel up...even with so-called premium. i'll give you an example...i recently fill up my g with high octane at a local gas station. the next day i noticed it wasn't running quite right for the first 30 seconds after a cold start. and it seemed really down on power. low and behold the local transporter had put diesel in the wrong underground take at the gas station! luckily it didn't harm my car...just caused a service engine soon light.
anyway, i loathe the word premium when associated with gasoline...'cause in many instances there really is nothing premium about it. imo, gas has been tagged premium to make people feel like they are treating themselves, and their vehicle better by burning this more expensive stuff, even when their vehicle gets absolutely no benefit from it.
I couldn't agree more bro. That was what I was saying, in far too many words.redhed wrote:
i suspect that if the electronics/hardware of a g35 loses it's ability to accurately advance or retard timing...it either won't run at all; or it will flash a "service engine soon" light.champagneG35 wrote:Ok I hope I don't start a huge debate about this but I just wanted to state one thing about the underlined portion above. Our cars or at least the 03 coupe I know has a 10.5 to 1 compression ratio. Now granted we have this smart computer that retards our timing should we have to put less than 91+ octane in it. On the same token however have you ever driven something with that high of compression without the computer on 87 octane ? I have. My two motorcycles a 1990 FZR1000 and it's little brother the FZR600 which have the same compression ratio and no computer will run absolutely like crap on 87 octane sputtering and popping and overall barely running coupled with dramatic power loss. So what happens if we're running 87 octane in our cars and the computer has a problem effectively eliminating the timing control. Now I'm not 100% positive but I would assume there is a preset default it will fall to should it have a problem like that and if I were to guess I would say that it would default to factory specs with recommended timing. That would mean at this stage there could be possible damage to the engine from knocking/or pinging. Just my 2 cents.
LOL... You're welcome Paul. Sorry for the long rants and raves. Unfortunately you "hooked" into a long-contested point here on the forum. That particular topic always sparks heated debate! (but I guess that was pretty obvious)Hookm36 wrote:so uughhhh................I think my question got answered.....
Thanks BigWill. !!
will continue to use Premium....
