Welcome to NICO!
Quote »(1) The cruise control does not work. The green light comes on in the cruise control switch when I turn the system on, but at freeway speed nothing happens when I push the SET button on the steering wheel. No CRUISE light, no response from the system.[/quote]
As they said check all your fuses very common for the horn button/cruise button to short near the spiral cable blowing a fuse. make sure you check both the fuses in the car and under the hood. If those are all ok then you likely have a problem with a contact part of the ciruit typically the brake pedal switch or the set/cancel/resume button on the side of the horn pad. There is a proceedure for putting the system in test mode and watching the light on the dash to blink every time a button is activated. I will go through some of my training manuals today and see if I can find the proceedure to put it in that mode.
Quote »(2) The security system doesn't arm when I lock the car. I tried all different kinds of things like locking with the little keychain transmitter, locking with key, etc. but the Security light doesn't come on for 30 seconds like the user manual says it should, and there is no response to "suspicious" activity to the car.[/quote]
Pop you hood and locate the pin switch that gets pushed down by the hood when its closed. usually somewhere along the radiator support. it is an accordian rubber boot with a 2 wire gray connector plugged into it. Unplug it, lock all your doors with the remote and see if that light comes on solid for 30 secs. If it does your swith is bad you could either replace it or just leave it unplugged. If that doesnt work then you need to do as heavy said and get into the door and see if that lock cyl switch is stuck in the unlock position.
Quote »(3) Power antenna is bent. Can I just replace the antenna part or does the entire assembly (dealer said they run around $200) have to be changed? We have a Pick-A-Part in the area; can I grab one from a Maxima or something or is this antenna Infiniti specific?[/quote]
Yes you can just replace the mast. I would recommend you get the one for a G20 from a dealer. The mast likely is used on other model nissan /infiniti's but not sure which ones. there 3 or 4 different thickness masts available. Like Rob said they are only like 20 each new. Since yours is only bent and not broke you can just remove the old mast and feed the new one in without pulling the whole motor from the car. Remove the nut at the base of the mast on the body. You can use a pair of snap ring pliers in the 2 small holes on either side of the nut to loosen it. once the nuts off turn on your radio and the ant will feed out. make sure you get a hold of it before it comes all the way out so it doesent fall and scratch the car. Take your new one and feed the plastic cable down in the tube and have some one turn the radio off. bob the cable up and down in there while rotating it till it grabs it and pulls it in. if the motor stops be fore you can feed it all the way in just turn the radio on and off again rapidly so it will restart the motor.
Quote »Also: Where is a good place to get more keychain transmitters or must they be purchased from the dealer, and how do they get "married" to the car?[/quote]
Ebay probably a good source or the dealer. There is a procedure for programming them to the car in the maxima tech section its pretty straight forward I will see if I can get ya the link..
Congrats on your new ride.
Scott
