FRITZ35 »
https://forums.nicoclub.com/fritz35-u149883.html
Sun Dec 20, 2009 8:37 am
Nick - I had a new FX45 in 2003 and it was quick from a dead stop. Two days ago, I bought a 2010 FX35 and drove two of them before deciding on which one to purchase. Here is my experience:
1) FX35-Umbria with wheat interior and 300 miles (dealer-trade miles they said).2) FX35-Umbria with graphite interior with 3 miles and nice brand new car smell.
First I drove #1 - In driving #1, I noticed that it was quite sluggish from a dead stop. Since I had not yet driven #2, I just thought it was the difference between an FX35 and my previous FX45. I also noticed a hard ride, so checked the tire pressure and the tires were around 45 psi per tire.
Then I drove #2 - This one was very quick from a dead stop, similar to my former FX45. It also rode better and in checking, the tires were around 35 psi per tire (so this must have accounted for the noticeable difference in the ride). #2 also had a new car smell that was noticeably different from #1 (maybe the dealer trade driver liked cigarettes ???).
I guess you can figure out which one I bought! (#2).
From my many years experience in buying new cars, have come to the conclusion that no two cars are the same, even though built to the same specs. Back in 1959 I bought a new Ford 2-door Country Sedan station wagon and my mother bought an identical new wagon at about the same time. Her car always had much more pep and got considerably better gas mileage. One time we drove both cars (together) from NE Ohio to Buffalo, both starting with full tanks. I had to fill my tank about 1/2 way back, but my mother's car ran all the way home and into the next week. About 2-3 years later I had an old-time mechanic take a very close look and he determined that my car (from the factory) had the timing set back (retarded) from factory specs. After my mechanic reset the timing, it ran better, but I traded it in shortly thereafter, so forgot about it until now.
So maybe you might want your Infiniti dealer to take a very good look at all of the specs. It could be a simple solution to a frustrating problem. I know that after driving the two FX35s, I told my wife that "they are not the same car". Luckily I took the time to drive both, as otherwise would have never known the difference, had I bought #1.
As to fuel, our previous M35X called for premium fuel. After the fuel prices increased so much, we went to mid-grade fuel for over 2 years, and I could not tell the difference. I haven't decided which fuel to use in the FX35 as yet, but will probably go for the mid-grade to save about 20 cents a gallon. I do not think fuel is the problem with your car - instead would look towards resetting the transmission and rechecking the ignition. Don't give up based on the dealer's word - your car should jump off the line from a dead start. Performance is "Infiniti's middle name" and the reason that most of us keep buying them. Good luck.
