gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Sun Dec 21, 2008 4:30 pm
i did talk to him earlier than that test he posted. i think it was back in october. his impression of the BW was that they are great turbos for the money, and often just as good or outperform their garrett counterparts. he mentioned that if it were late 2009 or so, BW would probably be the way to go, but garrett is tried and true. he said at the time they were having big issues with getting cores supplied from BW, and they were being dodgy about their inventory. he also said getting a rebuild on a BW is tougher than a garrett, but i'm not sure if that holds true anymore. one other thing to mention is the v-band outlet is slightly different on the BWs, which would mean i'd have to redo at least the beginning part of my downpipe. non-BB non-water cooled vs. BB water cooled has its pros and cons too.
one other drawback of the 1.06 35r is the turbine housing is really big compared to the frame. the 35r still has a small center section diameter, but the 1.06 turbine makes it swell onto much of the center section. getting to the bolts is a bit of a pain, but i found some pretty good fittings from ATP that helped big time. if you notice in the pics how my coolant lines are run, they are a bit unorthodox, but it really was tight in there.
