encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.html
Fri Jul 04, 2003 9:30 am
What do you mean grinding? You mean like squealing like metal on metal when you drive?
I has the same thing, but when I replaced the pads I didn't lubricate the back of the pads with brake grease (I used silicon white grease, which apparently doesn't work) and had mad squealing unless the brake was barely on or on full. After removing everything and using brake grease (very thick stuff) everything was fine. Remember this is on the back of your pads, not on the side that touches your rotor.
