yes im just waiting for the leds to come in the mail. they are a different size led then the gauge cluster ledsRobPaulson wrote:any plans to add climate control colors??
i did some research on the tundra it can be done its the same principle rip apart the whole gauge cluster to the bare bone desoldier all smd theirs alot of them and resolider new ones with the color of your choice you just need to get the same type of smd they are 3.5mm x 2.85mm LED the tundra gauge cluster is orange and very dim end result would look something like thiskyle@stillen wrote:These look awesome...can you do 07 Tundra's??? By the way, I found it really funny that the google banner ad that popped up when I saw this was about gauge cluster repair...just a random coincidence?
i have been actually doing alot of research on this what i ultimately want to do is have rgb leds in place of all the pre existing leds they would have to be on a custom circuit board powered from an external power source connect that to a multiline rgb controller which can be set up to change colors in sequence up to 16million different color variations and tie into that a controller which will basically allow the instrument cluster to be converted into a dynamic indication of your speed and engine RPMs. As you accelerate, LEDs will light up to indicate your current speed and engine RPM. The faster you go, the more LEDs will illuminate im still far from getting all that figured out what i need to find is the appropriate wiring diagram for the back of the wire harness specifically the ground wire, speed wire, power wire, and tach wire. if anyone knows were i can get that please help08Coupe wrote:Looks good, on my GTO I had my cluster's colors changed, also the needles changed colors as they went up...Any thought of that option? Also can you program the DIC to to say different things? We had our screen names pop up or Holden,also actavated a disabled shift light, the GM dealer got a kick out of it
hey check your email i sent you a replyaliadeel wrote:Hey surman...
neat job on the dash colors man.. listen I stay in United Arab Emirates - Dubai, Im interested on the Dash colors, but can the dash be sent to Dubai?
If so how much would be the charges? Also can you tell me the picture of the blue altima you have on your profile, are those headlights available, I have a V6 3.5 2008 Altima 4 door and how much would those cost with the shipping?
sounds good man whenever your readyMr.Coupe wrote:I might be interested in doing this soon. I'll contact you dude when I'm ready.
Ricky C.
sure hear is the video of the removal procedurealiadeel wrote:thanks a lot for the reply bro... but listen can you post a video of removing the dash first, so Ill see if i can get the dash out. One more question, in this part of the country, the speed is in Km/h on the dash, will that make a difference??
