So I decided to change up my setup some. Now have 2.5" pipes into a better X-pipe and have 2.5" Magnaflow Magnapaks at the exit of the X, in the location the stock resonators once resided. I removed the cutouts and the factory muffler section. Ran 2.5" tailpipes into the factory tips. Sound is somewhere between cutouts open and cutouts closed. It is very loud under acceleration and at startup but I like it and it is barely noticeable at highway cruising speeds unless you lay into it a bit going uphill or accelerating. No interior drone or annoying resonance at cruising speeds or under normal acceleration. Full throttle is not jearly as loud as when I had the cutouts open, dumped under the rear of the car prior. Sounds alot like a newer 5.0 Mustang with a catback on it.
Here is what it sounds like. Backed up against a concrete building it was louder than the microphone on my phone could handle. It is about twice as loud in person.
https://www.youtube.com/watch?v=vIRBIR19A1o
https://www.youtube.com/watch?v=XUAP5UjgWxg
I have not touched the tune up yet, but it is still the same torquey monster it has always been. Has no trouble laying rubber down from the P275/40R20s on the back. With the taller rear tires the speedo is still about 8% low. 56 mph on the speedo is right at 60 mph.
https://www.youtube.com/watch?v=mTwZkLSpQQc
