C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Jun 23, 2008 7:24 am
If you're going to replace the resonator, don't use a flowmaster in its place. While my observations with them tend to be wioth muffler replacements, one of the bigger issues is still the same. They simply do not flow well. They are a chambered muffler and will probably flow a little better than a typical OE muffler, but they do not compare to a good straight through design. Magnaflow and Walker Ultraflo mufflers are usually my pick. Interestingly, even with being a straight through muffler, they are better at suppressing noise as well. Flowmasters tend to be annoyongly loud and droning. Might not be to bad as a resonator, but the flow issue would still deter me from ever using one.
On a side note, I'm running a Magnaflow muffler on my truck and I do like the quality and thought put into it over the UltraFlo. Particularly with the Offset inlet/outlets. Instead of just welding a straight perforated pipe through at an angle from the inlet to the outlet, it uses a mandrel bent perforated pipe that smooths out the directional changes within the muffler. Though, I'm not sure if this is done in their smaller mufflers as mine is pretty big (Replaced the rather large Titan muffler).
