New Engine
BuudWeizErr
The Wartsila NSD (Sulzer) RTA96-C two-stroke diesel engine The most powerful and most efficient piston prime-mover in the world today. Bore of just under 3'2", stroke of just over 8'2". Available in 6 through 12 cylinder versions (all inline). Maximum continuous power of 89,640 HP is obtained at 100RPM with the 12 cylinder version. Maximum economy power of 53,244 HP is obtained at 90 RPM. The engine exceeded 100,000 horsepower during overspeed testing (all of 101.5 RPM!) while under test at Japan's Diesel Union works (who also built the first engines and from who these pictures are taken). Fuel consumption at maximum power is 0.278 lbs/HP/hour (BSFC). Fuel consumption at maximum economy is 0.260 lbs/HP/hour. The latter figure exceeds 50% thermal efficiency (i.e. more than 50% of the fuel going into the engine is converted to power). Compare with automotive and small aircraft spark-ignition engines with BSFCs in the 0.40-0.60 range and 25-30% thermal efficiency. Engine weight exceeds 2000 tons in the 12 cylinder version (the crankshaft alone exceeds 300 tons).
Note that, even at its most efficient power setting, the 12 cylinder version will consume nearly 1,660 gallons of heavy fuel oil an hour!
Someone posted that on my forum. It's pretty hardcore.
TrueSlide
Car: Stuff
Possible 240 swap???
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
HOOOLLLLLLLLLLY SHHIIIII!IIIT!!! THAT THING IS HUUUUUGE!!!
Mayhem_J30
Car: Ummm...My Car
Holy crap! I bet it's a biatch to clean the throttle body.
Anand
Car: 95 Nissan 240SX
what would you put that in!?!?!? If the engine is that big.. imagine the car/truck/automobile!!!
UncleBen
i'm thinking maybe a ship of somekind?
reggiegsd
Car: '94 Q, '73 240Z
Imagine the size of the starter motor.
Stoneage_Turbo
Car: 1994 Caddy Deville 4.9
Just about anything
"Holy crap! I bet it's a biatch to clean the throttle body."
naw , probably a broom,simple green,mop and a long walk inside a deep dark hole/tunnel , dees im sure you could elaborate
as for what its in , ive seen those in large crude carrying ships and stuff , 2 miles down the road off base here there is a crankshaft that was longer than my late G20 , will go take a pic of it this weekend , but id think theyd just run big locomotive engines tied to generators and have electric motors to drive the props ...moust be somekinda weird arse ship
those look like studs for mains to bolt to , with some big arse nuts
almost 100,000 hp and the vehicle its in will probably never go faster than 35 mph ....would sink faster than it could swim if the ship ever came apart
also first time ive ever seen hollow con rod journals
ninjak84
Car: S13, Z32, Titan
Hahaha! Yes Trueslide, I'll release pics of the install when I'm done ;)
theTony
Car: umm.....Cars??
Damn! Yup! It's engine swap time!! :cool:
It would be cool to see that thing fired up.
TrunkMonkey
Car: 2000 Lincoln Navigator
Stoneage_Turbo wrote:also first time ive ever seen hollow con rod journals
it's an old trick used to lighten the crankshaft. an added benefit is that it makes the counterweights more effective (not applicable in this case). most of the aftermarket crankshaft companies do it.
kinda funny though...
trying to lighten a 300 ton crankshaft.
demetrius
Stoneage_Turbo
Just about anything
"trying to lighten a 300 ton crankshaft."
yah , there only turning 100 rpm , yet they are concerned with lowering the rotational mass ....weird ..didnt think of that ...wonder what the deal is there
good idea to hollow that out tho , heard of cams done thata way but never the journals
TommyHawk
Car: racing, sim racing, NOT drag racing
Do you guys know where I can get some 1mm oversize pistons for mine? I'm looking to for some extra power. Figure that's good for 20,000hp. lol, maybe I'll break into the 13's.
(-8
Jean
Car: Wing chun
What are those Koreans thinking these days??? It must be that Kim chee?>>??
jemil118
Car: cars,cars,cars
I wonder how big a shot of nitrous it can take...hmmmm....:jump
Mike09
It needs some type "R" stickers that will add some serious power i'm sure.
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
jemil118 wrote:I wonder how big a shot of nitrous it can take...hmmmm....:jump
Don't you use propane instead of nitrous oxide for diesel engines?
MasterMan
Car: nothing running at the moment city buses "uck here
god damn thats massive.. wonder what they would use it for.. at only 100RMP its not vary useful...
