new engine or hottank it? 85,000 miles.
dl240sx
Car: rebuilding cars
gettting ready to turbo my car with the ka. have 85,000 miles and was wondering should i hot tanks the engine or just look for another low mile engine.
thanks
andrave
Car: 1989 Nissan 240SX Coupe
that IS a low mileage engine...
WDRacing
Do a compression test, if its good, boost away.
WD
dl240sx
how much hp can the stock ecu handle. i heard it was around 300 at the crank.
andrave
I don't understand the question, the ECU isn't "good for" any specific HP.
dl240sx
never mind i'm retarded it wasn't the ecu it was something else but forget it. is all the wiring hard to do? do you have a wiring diagram to turbo a 240sx(s14). don't really know much about the wiring and all the computer stuff.
thanks
Nathan
The wiring totally depends on what engine management you use as well as what gauges you put in, gauges are easy but a standalone with new sensors is more challenging. A JWT ecu is as easy as plugging it in but other engine management options might require an almost full re-wire of the engine related stuff.
dl240sx
nathan, live in dallas too? have you done this before?
toki
ahaha i'm sorry bro, but 85k miles and your worried. my KA is still on it's original parts with 203k miles and it still running 255 compression, KAs just don't crap out after 100k or anything. they live nice and long. Lots of altima people keep them around for 250+k miles.
don't worry unless the compression or leakdown readings are bad. If you want to be safe, the best thing to do other than internals is some head work, at which time you can get things cleaned up a bit and it should be dandy for boost.
dl240sx
toki, i know they run forever but didn't know if they ran well under boost. 203k damn and still running good. thats why i like nissan, they run forever unlike a ford or gm.thanks
Nathan
Well, I live in Denton, and my car is in Carrollton, I'll be putting the motor back in and plugging everything back in, in about a month probably, maybe a shade more...your welcome to come check it out if you want too!
dl240sx
ya send me an email when you doing the work.
[email protected]
Nathan
Allright man, I'll hit you up on AIM sometime too.
WDRacing
Awe....thats sweet...lol. I heard about you guys from TX.
WD
Nathan
There's a fair sized contingent of us Dallasites here ;)
andrave
yeah with any luck I'll be moving to houston in August. *we can hang out!*
dl240sx
does anyone have any specs on some good turbos for a s14. something in the 300hp range.
andrave
how expensive? GT25R would give you instant spool up and plenty of high end but its like 1200 minimum.
dl240sx
cheap as possable of course, but sometimes you have to pay alot for what you want. anything else or is there a sticky somewere, were i can find all this information out.
thanks
andrave
you could just browse through the forum, through the first 10 pages, and read up on what people are using, and read the replies to questions people ask.. it might give you a good idea.You could learn to read compressor maps and do some math and stuff too, but I'm not that good at that so I can't help you much there.
WDRacing
The T3/TO4E 50 trim .63 AR stg 3 wheel is ideal. I like the GT30 more then the GT25. But I don't mind a hint of lag.
WD
