PalmerWMD »
https://forums.nicoclub.com/palmerwmd-u108.html
Sat Mar 06, 2004 7:16 pm
This is gsr778 I couldn't log out of fred's name.
Since it is so early in the morning and i can't think to well i think that honda changed the ecu from 90 to 91 but not for sure. Also you may want to double check and make sure that you really are getting a spark. Take out a spark plug and attach it to the wire and make sure that your are indeed getting a spark. When i checked my spark all i felt was a shock but did not see a spark, so I thought that it was still producing a spark. As it turned out my coil was bad therefore producing a currnent but not a spark.
Also double check and see if the you got the right ecu for the engine. If you have an obd-0 ecu for and obd-1 engine then the engine may not fire up. You can check on the side of the ecu itself. It should say a P-someting (ie p13, p28, p08, p75, etc.). Let me know.
