New engine build for the G35's VQ35
mike800+rwhp
Car: 03 G35tt and 06 G35
I have been in this game a long time and know a lot of people that can tell you how to build a engine but do they really know. When my built engine took a craft from a bad oil pump I was a little mad but it gave me the chance to build a new engine. I decided to go with a engine building shop that has all the equipment you could dream of and the knowledge. I told them what I wanted and then they told me what I need for road racing. I wanted to sleeve the block but was told that the water passages are not as good in a sleeve block versus a open deck so we decided to go with the stock bore and leave the sleeves has thick as possible. Here are a few specs and pictures of the build.
JE pistons with 8.5 and 2618 T6 high tensile forged aluminum 95.5mm bore with a Ceramic/Moly Piston Coating
The new ERL Performance Main Girdle Pauter Rods E- 4340 chrome-moly forged rodARP Rod BoltsARP Main StudsBlock redeckedBlock Honed using a Torque PlateRotating assembly 100% balancedCrank magnafluxed and the journals micro-polishedNew Moly coated Race Spec main bearings installedNew Moly coated Race Spec rod bearings installedARP VQ35 L19 Head Stud torqued down to 90-95 ft/lbs
I am not looking to break any hp records I am just trying to run a good 600rwhp numbers all the time. More pictures and updates to come.
Modified by mike800+rwhp at 2:10 PM 7/10/2008
Modified by mike800+rwhp at 12:48 PM 7/11/2008
mike800+rwhp
Thanks for all the interest and support and here is the update on the intake manifold. With my old intake the torque was good in just ran out of air up top from the lack of volume, increase volume = horsepower so that's what I'm doing. I in trying to make it look like a professional welder made it but aluminum is so hard to make it look good but here's some pictures anyway.
C-Kwik
Sleeving the block in that of itself doesn't affect the cooling passages. Bracing or closing the deck can affect , but when power levels get high enough, it becomes necessary. Open deck blocks have a tendency to have the cylinders shift under high pressure, which can cause problems with head gasket sealing.
I'm not sure at what power levels that becomes necessary at, but I would check with some people who are experienced with building a high HP VQ. Bear in mind, if any more power could be in order later on, now would be the best time to do such work, rather than to have to pull the motor apart again.
Jacko3
Mike:
What are you doing to this car? Is there anything on that car that is stock anymore? How much power is enough? I am thrilled and intrigued at what can be done with a VQ engine. I wish I had the money to do the stuff you are doing. Well done!
mike800+rwhp
500 to 600 hp for 30 minutes is all I'm asking for and do it with no problems. That sounds easy right.
Jacko3
That is a lot to ask for the VQ engine. How much have you invested in this project so far?
mike800+rwhp
In the bottom end + machining I have a round $5,600 it makes me sick to think about the total amount. By no means have I invested all this money without some return. By going to track days and meets I have been able to make connections in my field of work.
TeflonG35
Car: 2003 G35 Sedan
You could always market those plenums ^_~
mike800+rwhp
Update on the intake manifold
TeflonG35
Car: 2003 G35 Sedan
Looks awesome. Keep us updated
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
I just busted my left
That's inspiring
Jacko3
This is really interesting! You do inspire me. Judging from the way you write and your tenacity/focus, you are probably a very disciplined individual. Well done! So, are you planning to add a turbo with that plenum? And, where did you get the idea that you could build your own plenum and parts? I bet infiniti/Nissan would be happy to have you as one of their engineers.
G_whizz
Car: 2010 G37 Coupe Sport
I agree with everyone here Mike...I enjoy learning and reading about your project and look forward to seeing it's completion.
Oh..and a whole Sheetload of vids please!!
Phenominal car... your a lucky man!!
mike800+rwhp
I got the motor on Saturday and will start assembling tonight and take some pictures of all the parts that make this car unique.
joe603
Car: 2014 Durango R/T
sounds good!! have fun with the install, and post up those pics
mike800+rwhp
Motor photos
TeflonG35
Car: 2003 G35 Sedan
Sex.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
Mike and I should start assembling this beast this weekend providing out schedules dont conflict....def gonna be one bad mofo.
Jacko3
Amazing how clean the internals of your engine is, given that you race the car. Do you use synthetic motor oil in your engine?
S14-NEO
yes he does use a synthetic oil but that engine has been freshly rebuilt complete with a nice long hot tanking session...hehe
hernandez5749
Car: '05 g35 coupe - some day with a ls swap
SICK!!!!!!!!!!
Focusedintntions
Car: 07 Infiniti G35 Coupe 6mt
More pics more pics!!!
That reminds me...i need to go get more lube...i just ran out looking at the rest...hehe
MUNNNJEE
sweet let us know what happens!
