GRADEST »
https://forums.nicoclub.com/gradest-u28856.html
Mon Sep 26, 2005 1:36 pm
I bought a 94 q45t in jan of this year and 1 mo. later it developed a head gasket leak. My coolant looked like chocolate milk. It started using as much water as gas. Weird thing is, i never had water in my oil? As a testament to the vh45de I ran it like this for 10,000 miles. I tryed to blow it up, it wouldnt give. I overheated to where it started to run bad and make all kind of clattering noises like at least 10 times. When it cooled off i added water, and went on my way. No prob. I ran it without a thermostat so it had good water flow. The oil in the water would gel when it cooled blocking flow on warm up. The car would still do 135 with one bad injector. there was oil leaking out of every gasket on the thing. So, 165000 miles on a mess of an engine, and i still put another 10000 on it.
I picked up a 40000mile us spec motor from a salvage co. called greenleaf for 1100.00 here in LV, NV. I installed the new engine in the car 2 weeks ago. It took about three days or thirty six hours with all hand tools(no air). It was challenging with no lift to use. I did a combination of jacking up the front of the car, then lowering the motor/transmission combo with a cherry picker and actually set the combo on the hoist's legs to roll it out the front of the car. The salvage co said it was a 94 but it had a different crank pulley with only a 4 rib where the P.S. / water pump belt goes. Mine has a six rib pulley for the P.S/ water pump belt location. I used that handy sears puller, a chain wrench, and a three foot breaker bar to do the swap. The biggest challenge was all the little clips and retainers that are brittle and wiring harnesses that are time consuming to remove. I love the new engine and this car is incredible. I would recommend to anyone to just swap in the low mileage engine and just be done with all the headache. With the price of parts and down time it doesnt make sense to drop the motor or do major repairs to this car. I would like to add this IS NOT a novice mechanics job. You need to be extremly meticulous and have extreme patience. to be 110 percent succesful. I would like to thank all the people on this forum for being involved and sharing knowledge of this car. And a special thanks to ELWESSO @ q45.org for helping me with a shop manual and his personal time for an advise phonecall. My next mission is a remote mount turbo. A company called squires turbo in utah does them. Check it out. That is unless somebody makes a supercharger KIT first!
