es.biggs »
https://forums.nicoclub.com/es-biggs-u154499.html
Mon Aug 16, 2010 8:42 pm
search and you will find more details, but in a nutshell you hook it to your battery with the power/ground leads. Then you look at your ptu, and there will be a black wire hanging out that kinda goes in a loop, looks like its out of place. It actually serves a purpose: hook the inductive pickup on the timing light to that black wire. Then start the car and aim at the crank pulley; watch for the tick mark to light up somewhere on the pulley before it gets to the top. There is a bracket with number 30..20..10..0 I think it goes. You want to adjust the CAS to where the mark lights up at 15. If you are at 10, loosen the CAS bolts and LIGHTLY tap it to counterclockwise (were talking millimeters here) to advance the timing. Vice versa if you are on the 20 side. Tighten down, start up and check again. Repeat until its right at 15.
