New Dyno #s - Stock Internals at 8 & 10psi
NateDogg
Well, I am pretty happy with the results..
Here is my setup:-Turbonetics ball bearing T3/T04E 57 Trim .50 A/R Compressor .63 A/R Turbine-555cc Nismo Injectors-Enthalpy Tune for 93 octane (I run 94)-Oil catch can a la beesandgoats.com integra kit-PWR I/C-2.5" IC pipes-HKS SSQV (Re-circulated)-Stock ignition-Aurora plug wires-NGK BKR6E plugs at .032"-3" DP-2.5" dynomax cat-Stock cat-back-3" E-cutout before cat
The red is with the e-cutout open (boost went up to 9.5psi)Blue run is through stock exhaust (cutout closed) at 8psi
j-z
Car: 95 240sx
45 more hp from 1.5 psi of boost is really good. those are some really good numbers. man i really need to get an enthalpy ecu....
KATwo40
Car: 1993 240sx KA-T
I don't understand why you ran it up to only 6k rpm?
Very good chart, btw. Gratz!
NateDogg
Thanks guys.
I ran it to 6700rpm on the tach but I guess it didnt register that high. I was just pretty spooked with the open dump being so loud and not wanting to 'nade the engine on the dyno.
KATwo40
Most likely your stock tach is off. The inductive clamp used on the dyno is the most accurate. I know that my tach reads about 500rpm's lower than the SAFC2 shows near the redline mark.
Either way, good job on the setup and the numbers.
Draginzuzu
whoa nice..open downpipe made a big diff
DRFT(kinda)
Car: 2005 Nissan Titan.
Nice numbers. Give me hope for my car =)
Jookmasta
wow so ur still running a stock exhaust? that could be the reason for such the big difference............good job with the numbers. how much was that turbo btw?
NateDogg
Jookmasta wrote:wow so ur still running a stock exhaust? that could be the reason for such the big difference............good job with the numbers. how much was that turbo btw?
Yah still stock cat-back but I have a DMHPerformance.com e-cutout before the cat on the downpipe.
I would say the stock exhaust costs 20-25whp if we attribute 10hp/psi since the open downpipe was at 9.5psi and the stock exhaust was 7.5psi . (45-(2*10)=25).
I got the turbo used for $375 off NICO
1WheelWonder
Car: 1991 Nissan 240sx
Damn nice numbers
fiznat
Car: Grown up :(
Very nice man, hows the car feel?
Florida240sx
Seriously got to get my car down to tampa.....MY buddy on stock internals is close to beatign me and he is at 5psi...I'm running 13-15....damn timing..Because he can go to redlien and I can't he gets a nice run on me and then 3rd gear I usually go past him and 4th I walk away....
Jookmasta
man that was a hell of a deal for that turbo.................
Holy CRAP!
This makes me desperately want to get mine on a dyno!!!!
GlacierFreeze
Car: '97 240sx (the tortise)
Great idea, stock exhaust for quiet cruising.E-cutout for large power gain but louder for racing.
edit... How much louder btw? The turbine blades should cut down on some of the sound, compared to NA.
gaehrings13
Car: Nissan S14
Not bad dude nice numbers.... Nice setup...
NateDogg
GlacierFreeze wrote:Great idea, stock exhaust for quiet cruising.E-cutout for large power gain but louder for racing.
Thanks for the comments.
The cutout is very loud. It vibrates the seat and has a crazy sound to it. Very intoxicating! I am thinkin of puttin a 90* downturn on it to make it a little more bear-able.
GlacierFreeze
NateDogg wrote:Thanks for the comments.
Not sure how long/big they are but maybe put a couple resonators before the cutout?? Supposedly dampens sound without much/if any exhaust flow interferance at all.
NateDogg
Check out dmhperformance.com
It is way too short to add a resonator unless you do it after the opening.
I couldnt be much happier. I'm going to the drag strip tomorrow to see what it'll run.
MarkEmark
Car: fully-built '95 240sx KA-T
E-cutouts are the HEAT!
I have one and surprisingly, a 90 degree turn down DID help a little bit with the noise/vibration...I can cruise around town in vacuum and not even really turn heads...l
Reno
Car: 89 S13, boosted.. RAWR..
Bump?
hannibal
Car: Red Line to Glenmont
Whats the bump for???
Awesome numbers!
NateDogg
I've since swapped out the Enthalpy for a custom tune by myself. I tuned fuel with a Innovate LC-1 and timing was advanced between 7-9 degrees throughout. I feel its quite a bit more responsive and pulls better even at 7psi.
Hopefully I'll get some new dyno numbers as soon as I put the new feramic clutch in.
sunnys14
Car: S14
so whats the deal with alot of KA-T owners not satisfied with enthalpy tunes?
Florida240sx
I'm happy with mine. Yes it has a bit of timing retard, but it keeps you safe. I could run 87 and be safe most likely. How many threads have you read: My Enthalpy ECU blew my engine up... haven't read any.... he is good at what he does. From he reading information and sending a ecu that has dead on a/f and is hassle free, how can you complain. You want the extra power bring to him and dyno. I just run more psi and I'm safe
NateDogg
sunnys14 wrote:so whats the deal with alot of KA-T owners not satisfied with enthalpy tunes?
After I got my car dyno'd I requested another couple chips with a leaned out top end (was running 10:1 AFR). I got the chips in the mail and put them in. I then loaded the .bin to see what he did an all that he did was to shorten the injector latency which caused my engine to idle real lean and, in generalrun ****ty. I also experienced compressor surge and turbulence at the MAF during this time.
So after 10 emails, an insulting email and a month of excuses I decided to be proactive and make my own tune. I did that but fried the enthalpy board (maybe his circuit board is encrypted) so I ended up with a PLMS board and the option for 4 map switching. Innovate LC-1 later and I'm tuning by myself
nissanfanatic
Car: 1992 Nissan 240sx SE
Could you tune a car spot on based on an email?
I really can't complain.. His tune has held my car together for two years now even with probably 6 months of that being at 400whp+ and a lot of WOT time..
myRed240
Car: '95 Nissan 240SX with a KA-T!
'07 Audi A3 2.0T DSG
'11 G37S Sedan
NateDogg wrote:So after 10 emails, an insulting email and a month of excuses I decided to be proactive and make my own tune. I did that but fried the enthalpy board (maybe his circuit board is encrypted) so I ended up with a PLMS board and the option for 4 map switching. Innovate LC-1 later and I'm tuning by myself
Can you give me more info on diy tuning? I'm really interested in doing it this summer. I'm interested in: what's needed, how much does it cost, how difficult is it?
Can you email me some more info? Or can I email you and ask questions as I get more involved?
Thanks,
Alex
Modified by myRed240 at 3:38 PM 5/11/2007
WDRacing
Awsome!!!
Well done man
sicride
Car: 1989 KA24ET RPS13
NateDogg wrote:Check out dmhperformance.com
Psh after 7 months and a revival of your thread... you still haven't told us what you ran that day?
