Darius wrote:LOL I was thinking the same thing. ONLY 20psi? I was hoping to see something around 30 or more. Seriously nice numbers! That turbo must be flowing some serious air to push that much HP out at such a relatively low pressure level. At what rpm does your GT42 fully spool? And what turbine A/R are you running? I can't remember off the top of my head.
I believe it had tull boost (20psi) around 6500 or so, its in the logs, I cant remember.
I am running the 1.01 hotside on this setup
I would have gone higher on the boost however going over 21psi I was hitting some type of fuel cut, and I couldnt figure out what parameter was jacked up in the AEM causing me to fuel cut. I sent the calibration file off to a friend and he just called me a few mins ago and told me that the boost fuel correction table had some type of error in it. Sure enough I looked at it was showing at 19psi to add in 140% extra fuel, 21psi to add in -98% fuel, and at 24 psi to add in 185% extra fuel.......so bingo, I changed the 21psi setting to 160% like it should be, and Im for certain that was the problem.
I dont want to push this thing too much further, I am still on a stock block/head with only a tomei headgasket and arp headstuds!
