New dyno numbers
fabio420
Car: 1995 nissan 240sx se
So I finally went to the dyno to see what I could produce with the 370cc's injectors and z32 MAF and kept uping the boost. Finally my best numbers were: 251.34 rwhp and 300.79 lbs of torque. Now being that the car is automatic, it has power and torque spikes. So on a all gear pull it actually spiked at 393 lbs of torque. I know it doesn't mean anything, but it's cool to see on paper a number that high. If you don't know, my turbo , which is a tiny t3, started to loose efficiency at 5000rpm, but I had 14psi at 3800rpm. So for low end torque ( which was my goal) I'm happy with it.
crzycav86
Car: 93 Nissan 240SX KAT
What did the wideband look like? Can you post up a graph?
I'm thinking you went dangerously lean at peak torque
fabio420
I have to take pictures and upload them, but the a/f ratio was steady between 11.2 and 11.7
Jookmasta
those are some impressive numbers. what was ur timing set at? and also what fuel pump are u using and do u have an adjustable fpr? congrats tho.
fabio420
Got a Walboro 255 for fuel pump. Stock FPR. Timing is set I believe @ 15. Horray for the small turbo!
fabio420
Hey jookmasta. You are from south fla, so we should head out to Moroso together this wednesday, or the next. I'm beggining to meet some people with 240's down here, but no one seem to know one another. We need to flex our "muscles"
Jookmasta
there are four other ka-t's i know of down here. but ur the only one i know of in broward. there is a local meet up every thursday but its all the way down in kendall. email me at [email protected] and we can chat there.
dont want to clog up the thread too much. congrats again on the numbers.
crzycav86
fabio420 wrote:I have to take pictures and upload them, but the a/f ratio was steady between 11.2 and 11.7
Well those are some great numbers. Congrats.
Florida240sx
I want that...more torque the hp. Like 200 hp but 350 torque
1WheelWonder
Car: 1991 Nissan 240sx
Awesome numbers man.
Nismo_Freak
Car: 89 Nissan 240SX
Florida240sx wrote:I want that...more torque the hp. Like 200 hp but 350 torque
Buy a V8, but if you make 200whp with a V8 I will laugh at you.
Florida240sx
Yea that would be pathetic.I was joking with those numbers but would like to have more torque than hp
foley
my truck has a 6 cyl... makes about 400 hp and 650 ft-lb ... but that's diesel
If you want more torque than hp, you're into the wrong kind of car/ engine. You need to be looking for less rpm... look for something big displacement, with a long stroke. longer strokes typically mean more tq, less hp. Also, inline motors typically make more torque than hp due to the longer crankshaft driving more rotating mass and resulting in lower rpm numbers
crzycav86
foley wrote:my truck has a 6 cyl... makes about 400 hp and 650 ft-lb ... but that's diesel
Compared to other import 4-cyl. motors, the ka is pretty big and has quite a long stroke It's the truck motor of the import 4-cylinders.
