New Drop! Eibachs
All things Altima Coupe.
Sam1ch
Car: 2010 Altima Coupe 2.5
Installed the Eibach Pro kit today. With the help of my friend it took about 6-7 hours. I love the ride and look. If your wondering about the big dent in my car, here is the thread friend-backed-into-my-car-need-advice-t532907.html
*When installing the front springs there was no way of placing them where the Eibach logo was readable. It had to be upside down although I put them right side up for the rear.
elfenlied8
Car: Altima Coupe 2010 2.5S
hella sunk + unslammed. So when you getting rims???
pc240sx
Car: 1993 nissan 240sx se
2003 nissan Sentra se R SPEC V
2025 nissan Frontier PRO X
looking good .
DAAN.
Looks nice
so those are the '10 '11 wheels
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
Sam1ch wrote:*When installing the front springs there was no way of placing them where the Eibach logo was readable. It had to be upside down although I put the right side up for the rear.
Fronts are installed incorrectly. Eibach states the proper installation is so that the logo is legible. You have the fronts in upside down, you need to flip them.
Sam1ch
Thanks guys. Rims will be my next purchase. Still debating on which ones to buy.
The last picture shown is of the front spring. There was no way for us to install them with the logo being legible and the logos started to rub off. Also a DIY thread said to shave some rubber but I didn't know what exactly to shave so I didn't. What are the consequences?
boystar22
Car: 2008 Nissan Altima Coupe 2.5S
There was no way my fronts would go on with the logo right side up either but they fit perfect upside down too. I haven't had any problems with mine so far.
DJ_B_Easy
Its a bushing that you have to shave, but I thought that was for the rear? Anyway, I couldnt even tell you what consequences could be. Springs might compress differently if the load hits from one end or the other? A few members have had the springs literally break on them. I just know that was a specific thing mentioned in the installation instructions, I like to go by the book as much as possible.
boystar22
DJBeasy wrote:Its a bushing that you have to shave, but I thought that was for the rear? Anyway, I couldnt even tell you what consequences could be. Springs might compress differently if the load hits from one end or the other? A few members have had the springs literally break on them. I just know that was a specific thing mentioned in the installation instructions, I like to go by the book as much as possible.
I remember having to shave the bumpstop, and I did do that to mine. But the plastic hat that sits inside the top coil of the spring is just far too big to fit inside the top coil. But It fits perfectly in the bottom. I'm not convinced that mine aren't right side up and Eibach printed their logo upside down by mistake.
DJ_B_Easy
boystar22 wrote::spitout:
Yeeeeahhhhh. Was just making a suggestion bro, but this is cute.
boystar22
I didn't purposely add that. Must have clicked the stupid thing on accident.
scionsoloxb
i just put on my springs 2 weeks ago, and i agree with other's here. the letters are upside down on the fronts it just fit better. i also trimmed my bump stops about 1" on the fronts. wish the front spring's was as easy as the rear spring's. :) looks good!
Sam1ch
What's the point in trimming it?
InfinitiEric
Needs to be lowerrr
6EXYSIXER
Car: 08 altima coupe
yeah imo the front sits weird... looks good in the back but too much wheel gap on front for my taste
obstacle
Car: 2010 Altima Coupe 2.5 MT Winter Frost
beginning with 2010, the 2.5s only get 17's. If mine were 18's, id be all over lowering mine. hence why i havent dropped...waiting til i need new tires to upgrade and lower
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
I think it looks sweet I love seeing our stockish car I miss mine...
Sam1ch
I think it is raised higher than the rear because the springs were probably made for the 3.5 even though they fit the 2.5 version. The 3.5s are heavier which should cause the front to sag just a bit more.
DLO310
Car: 2016 Nissan Rogue SL
2010 Nissan Murano SL
2011 Nissan Altima Coupe 2.5 S
2004 Nissan Murano SL AWD
obstacle wrote:beginning with 2010, the 2.5s only get 17's. If mine were 18's, id be all over lowering mine. hence why i havent dropped...waiting til i need new tires to upgrade and lower
whats the down side of lowering on 17's? i have an 2011- 2.5s and was considering a drop on eibachs
boystar22
I'm running on 17s and I haven't noticed any downsides compared to a larger wheel. If anything the extra sidewall makes the ride slightly softer and less harsh on pot holes and rough roads. Handling wise it should be the same as an 18" wheel (if the tires are the same).
theneo01
I also had to install my front springs upside down. They work great so eibach is obviously a bunch of retards who cant even figure out what way there own springs are supposed to go. haha
