Dennis, thanks for the info on ATF fluid. I've leaned much this past month since I discovered NICO, and I've gotten the majority of my knowledge from your posts. It's a rare thing to be able to accept someone's advice as gospel, as opposed to some who want to seem knowledgeable so they "shoot from the hip" (referring to most messsage boards).So thanks again for all the great advice. You and others have saved me 1K since I bought my car last month.
My 94 factory service manual is still on backorder (books4cars) and they say could be for some time.
I also have a 94 Q and have been wondering the same thing about the factory "front" filter.
So..... in your opinion should owners replace the front factory trans filter? If so at what mileage typically? I'm betting you've disected an old one, haven't you
I recently ordered an inline filter kit, so should I simply bypass the factory filter?
I also plan to add an aux trans cooler this spring, so I assume the factory "front" filter would be bypassed anyway?
In the Infiniti dealer svc records it lists "JOB: TSS Comments: service automatic trans. " What does this mean was done? Or is it just a generic term which could be a multitude of things? This was performed at 35k miles.
Here's a brief summary of my car:
Bought last month (94) with 127,000 miles, and looks better than most 2 year old cars. The PO was meticulous, he just didn't know he should do more than the factory minimum.
I've changed all fluids except coolant (will do this week when changing water pump)
All recomended factory service done by the PO, not that that's saying much. Trans fluid was changed/flushed/screen replaced by me last week, but surprisingly it wasn't that much darker than new. The pan was fairly clean, 1/8 ferrous material on the magnet, and filter screen looked clean except for a tan coloring of the screen. (I assume this is the clutch binder material ?)
BTW, here's a little feedback for all of you. I replaced my noisy fuel pump last week, and it cured the following problem:
Upon max acceleration the engines power would fluctuate up and down, but not to the point I'd call it hesitation, it just felt like I was slightly letting off the gas, and then pressing it down again.
Thanks,
Kevin
