fejus wrote: I installed a new Deck the other day (Pioneer avh-p4100dvd), and now the amp in the back isn't turning on. Its the factory amp that came with the car with the Fosgate sub.
I have double checked that the remote turn on wire is all hooked up to the Powered Antenna as well as the harness. I have also connected the remote turn on wire to a relay that controls the DVD bypass. However, I have completely disconnected all of those and gone straight from the head unit to the harness.
Its the same harness for the Versa so I have been searching the forums there too to no avail.
thanks for any help anyone can render.
Paul
UUuuuh! tuff one! there.i am not sure if this is the fix but i think you may need a converter for your amp.back when i started with the xterra sound the guys at the sound shop were saying i was going to need a double bracket, one for the new stereo and a new one for the amp.at first i was like no way man!! but they actually showed me a website were it stated i need it if my xterra came with the premium rockford systemlater i found out i had the cheap system so i didnt need that bracket.check with your local sound shop and hopefully they can help you with itgood luck with it
