s13 drifta »
https://forums.nicoclub.com/s13-drifta-u44575.html
Wed Jun 06, 2007 2:21 pm
[QUOTE=SPIRONIUM]use common sense, route the lines back to their origin and figure out if can/should be deleted or not. There should be NO open connections to the atmosphere, but at the same time if you plug up certain lines your car will not run correctly.
Listen, this is not something you should explore on your own, there is a write up on this topic if you search. Use the writeup as a learning tool for this and later try experimenting on your own with something else once you have gathered up some experiance.
You can't just be plugging up or 'customizing' random things without knowing what their respective purpose is exactly, it is very unscientific and generally makes no sense.
Every part on the car has a job, if you don't understand what it does and how it works then you shouldnt mess with it. Its just a rule of thimb i suppose. Anyway good luck with your car
/end
I didnt really feel like bumping this thread up because I already fixed my problem, but the only way I learn how to work on cars is by doing everything hands on. Ive learnt everything myself and the best way I learn is experimenting and trying to fix things instead of taking my cars to the shop. I dont know a whole lot and Im still learning stuff everyday, thats why I asked the question, and yes I tried searching, but I couldnt find anything useful.
