Ebay for convertible service manual...
http://cgi.ebay.com/ebaymotors...=WDVW
As for your door switch.. Check the side of the door. You should see a little plug sort of thing that gets compressed when the door closes on it. That switch tells the lights and chime that door is open. Check on the passenger side door first, you should see it open up with the door. My guess is that the driver side door switch is jammed or blocked or stuck or something like that and is just not popping open with the door. If that is not it, if you can get at the wiring inside, I would venture a guess that you have a wire disconnected.
If you can't find it, I will post a picture later of what to look for.
I wouldn't sweat the e-brake too much. I don't think you will hurt the transmission by leaving it locked in park. Even if it is the ebrake, those are usually pretty easy fixes. Take it to a mechanic and have him check the cable. Might be severed, or stretched too far, or just not hooked up to the handle. You should talk to the previous owner of the car to see how long it's been since the ebrake was working if you can. Common thought is that if you want to use the ebrake, use it all the time.. if you don't want to use it, don't ever use it. If you go for a very long time without, then all of a sudden use it, it can lock in, and not work very well. My dad found this out the hard way and put his van in the ditch years ago becuase it didn't disengage.
I am sure you will fine some 'vert owners in LA. Not sure of any on this board though. Go back and check the roll call thread to see if people on there posted their location.
Get some pics up when you can. Must be nice to get a leather one. Mind sharing what you paid, how many miles, etc...
About the boot... talk to Dan (Danrc30). He has one for sale right now. He's a great guy.. no worries buying from him. Check his post for details...
http://www.nicoclub.com/zerothread?id=96854
last time I talked to him, he also had a 'vert top and window brand new if you need those.
Good luck! Congrats on the new car! Welcome to the best 'vert forum on the net!
