New compressor for my 99 QT
ZMARKUS
Car: 1999 Infiniti Q45T
2002 Infiniti Q45
Im in need of replacing my compressor. I'm told by my mechanic who works on only Nissans and Infinities that his luck has been bad with aftermarket compressors for this vehicle. He suggests factory for this job but will put anything I want on. My question is, has anyone had problems out of a aftermarket compressor for this model Q. On the other hand, should I just follow my mechanics suggestion and go factory?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
The question should be, "Has anyone had problems with the OEM compressor?"
To which, as far as I can recall, is "No!" It only fails if it gets dirty through an open system. That's on the owner, usually.
So, if you are content for a few more miles, maybe aftermarket is the way to go.
ZMARKUS
2002 Infiniti Q45
maxnix wrote:The question should be, "Has anyone had problems with the OEM compressor?"
I agree, the OEM compressors are fine. To be accurate, its not that it has stopped cooling. Couple days back the engine was just louder but performance wasn't affected. No fluid issues nor CEL. My mechanic said the noise is coming from the compressor and removed the belt to prevent it from locking up.
qship96
Car: 1996 Infiniti Q45
you need a new compressor.How much longer do you plan to own the car? If your answer is a few years or longer,go with a factory part....if a year or so,your decision to roll the dice and try a remanned generic.
rabsusa
Car: 1995 Silver mist Q45t 79 k miles
1994 Black Base 89 k miles - spares car(trans broke)
-- run it till it stops cooling and replace based on decision to keep the car... dont be afraid
