New clutch smells like its burning out....
lethaldosethrash
Car: 89 240sx (single cam)
I installed a new clutch in my s13 after a friend of mine burnt out my old one...But it still smells like it is burning; i am going real easy on it and it's not slipping...Is this normal or is something wrong?
180fan
Car: 89 fastback
are you trying to drive it like you normally did before? clutches have a break in period where you should drive a bit like a granny till it's broken in.
lethaldosethrash
180fan wrote:are you trying to drive it like you normally did before? clutches have a break in period where you should drive a bit like a granny till it's broken in.
I've been driving real easily...could it still smell from the old clutch.... it's only been a couple of days and my buddy really had it bad ( i could smell it on my clothes )
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
As long as you resurfaced the flywheel when you installed the new clutch you should be fine. Break in period for a new clutch is roughly 500 miles.
It will probably smell while your braking it in. Your brakes do the same thing. When I put new pads and rotors on they smoked and smelled like sh*t for a few days. As long as it holds and you are taking it easy don't worry about it.
