New Clutch Installed and had a little problem please help!!!!!!!!!!
Ericksilvia
Car: Nissan 240sx
I just installed a new F-1 stage 3 racing clutch with a 15lb flywheel. The problem I had was that the clutch slave does not reach the fork for the pressure plate. Can someone please help me out. Thanks
Hijacker
Car: '92 240sx Convertible
'94 F-150
Did you install the throw out bearing?
Is the pressure plate pushing the clutch fork back into its engaged position?
Can you wiggle the fork with your hand? So that it moves a good half an inch or so.
Ericksilvia
Car: Nissan 240sx
Yes i threw in the throw out bearing.
No the pressure plate is not pushing the clutch into its original position.
Yes i can wiggle the fork like one inch.
