I am still trying to figure out some info from your previous thread on this subject. fbpem1 specifically mentioned his preference for chromoly, mentioned that aluminium would be lighter weight and cheaper but did not even mention forged steel. I promise that I am not trying to give you a complex or anythingjoe603 wrote:I'm not sure on the weight...but it is significantly lighter than stock. The dealership gave me the OEM clutch/flywheel and those two boxes are much heaver than the aftermarket parts. The literature said that it's a forged steel lightweight flywheel...I couldn't imagine something lighter, it would be hard to manage at stoplights!
Yea right ....you don't even know your own flywheel's weightjoe603 wrote:I would think that forged steel wouldn't have warping issues like aluminum would...
Dammit! You would ask me that question! Hold on. I'll go check. My memory says 25lbs, but that's probably off. I've seen quite a few places state that the clutch/flywheel combo were 32. brb.joe603 wrote:What is the OEM flywheel weight?
Sorry for jumping in late on this, but just ran across the thread...the weight on the competition clutch flywheel is 14.11 lbseZg001 wrote:I looked at Competition Clutch's website and it gives a range of flywheel weights dependant on application. I couldn't find the exact weight of the one for the G35. Do you know?
I'm still trying to decipher info from your last thread concerning this. Exedy has a chromoly which one tech liked, I think it is app 19 lbs. Yours is steel, I think. The lightest weight are aluminium around 14 lbs.
obviously lightest is best for acceleration but trying to weight that with longevity. Not sure how thermal expansion plays a role.......
Modified by eZg001 at 6:42 PM 12/10/2008
Modified by eZg001 at 6:43 PM 12/10/2008
Interesting information. The stock flywheel is around 25 based on my limited research. IIRC, the stock flywheel/clutch combo is 32lbs.eZg001 wrote:So what is the scoop on Chromoly? And any quesses why the tech , not Steve, perferred chromoly for flywheels?
Just found this:
JUN Auto lightweight flywheels are one piece and made of Chromoly. These JUN AUTO Chromoly lightweight flywheels are 200% stronger than stock steel flywheels. The JUN Racing lightweight flywheels allow the engine to rev up faster, allowing you to power thru your power band quicker. JUN Auto lightweight flywheels will balance better than two piece aluminum flywheels and will not separate like two piece flywheels. JUN RACING engineers each application for the optimal weight to maintain torque, top end and balance of the motor.
The one for our G's is 14.3 lbs and $475
the Exedy is 20 lbs and closer to $600
How many lbs was the stock flywheel?
I found that one already and I didn't use it because it specified HR engine. I assume that one is heavier.eZg001 wrote:From Forged Performance's website:
JWT Flywheel 350Z / G35 / G37 w/HR engines (2 throttles) #16512 This low inertia flywheel weighs in at only 15.4lbs. Cutting the weight of the stock dual mass unit by 45% allows the VQ engine to instantly respond to its true potential. Deceleration is also improved allowing the engine to quickly slow the car with less load on the brakes. using my wicked mathmatical skills I get 15.4/.45= 34.22 lbs
