new clutch+flywheel= BAD STARTER GRONDING NOISE
gotboost1099
Car: Drop Top TT z32
brand new z1 stage 2 clutch + lightened flywheel. never had any starter noises before. any ideas>
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
you got the right flywheel? the TT flywheel si larger than the n/a so if you have an n/a trans on a converted car than you need the n/a flywheel
gotboost1099
its a turbo flywheel on a turbo trans
gotboost1099
called z1 and they said they had defective flywheels last year they will warrentee it but not labour. wtffff
evildky
06 Nissan 350Z GT
nit sure how a flywheel can be defective, a crack would have been obvious I suppose the mounting surface can be just a hair out of phase wiht the disk surface?
gotboost1099
they said teeth were cut on a super small agngle off what it should be
Ksizz13
Car: 1990 Nissan 300zx
I had to replace my starter when i first bought my car. I accidentally put the wrong bolt in the starter and it made a grinding noise agaist the flywheel, check your starter and that its properly installed
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
That is completely possible, and I've seen that before where an aftermarket manufacturer gets it wrong and the starter drive gear won't engage properly. Some of the older RPS flywheels had the ring gear welds crack even to the point where it came right off the flywheel on some rare occasions....nothing is perfect all the time, just the way it is. Even the best suppliers sometimes have issues.
Auto parts people will most often warranty the part, but almost never the labor.
Modified by Zwicked at 7:15 PM 3/8/2010
mkrinc
Ksizz13 wrote:I had to replace my starter when i first bought my car. I accidentally put the wrong bolt in the starter and it made a grinding noise agaist the flywheel, check your starter and that its properly installed
Any chance you know what the correct bolt size is?
zxequalslife
Car: 1990 300zx TT
The flywheel from Z1 is a piece of crap. I have it on my Z and there's like a dip in the teeth. Sometimes when I start the car the starter gear grinds because it doesn't make proper contact with that section.
I'm going to replace it but there's really no point to do that right now because I'm probably going to be pulling the engine this winter for a rebuild. Probably going to get a JWT.
