FDAPolice »
https://forums.nicoclub.com/fdapolice-u3740.html
Tue Sep 23, 2003 10:15 am
Hey, I have a 98 240sx and I just replaced the stock flywheel with a fidanza light weight flywheel also I replaced the stock clutch with a ACT Clutch Xtreme kit. it came with the pilot bearing, throw out bearing and alignment tool. When I was putting it together I noticed that the throw out bearing was a bit different but it fit. The model number for that bearing is RB016. I made sure that the spinning part of the bearing sits on the pressure plate. now that everything is done and bolted back up, whenever I start the car it sounds like the engine starts to quick and the starter motor is still engaged. THis is only for alittle bit. I was told that the starter motor might have to be aligned correctly. Also I still have the stock slop in the clutch pedal. I hate that feeling. Anyone have any ideas on why this is happening? Did I do something wrong? Thanks in advance.
