new car, new problem
bcar240
Car: 1993 240SX HB
I just got a nice 1993 fastback, and I am really happy so far (cept for the injen intake falling off on a sharp turn.) But somehow I managed to run over a nail and it is making my tire leak like crazy. The only problem is the car has a set of ADR design rims on it and after a search of the car i have determined the previous owner didn't include a lug key for them. I was at an autozone and the guy said that these custom lugs are all unique and I would have to use pliers to remove the lugs and get another set that came with a key. I am not very keen to removing sunk in lug nuts with pliers, and not ready to take that advice without confirmation. What is the best way to get this tire off? Also, as a side note, what is the best way to patch a tire? TIA.
Altiman94
Car: 1989 Nissan 240SX
find a socket that just about fits them and pound it on with a hamer and then turn it off like that. Also, when you get them off replac ethe lugs with new ones and also take the leaky tire into a shop and have them patch it for you.
bcar240
Car: 1993 240SX HB
I might have to end up doing that. I can probably find a socket about the right size, but it will be close cause the nuts are recessed into the wheel nearly all the way with only a narrow gap for a tool. Yeah, last time I took a tire in they just plugged it, I mean I could have done that myself, I guess I will have to explain to them what to do!
Soy
Car: '03 Mazdaspeed Protege #295
You're just going to have to break off the lock-lugs. Like Altiman94 said - take a similar-sized ratchet, pound the hell out of it, then unscrew. If you use an extention and are VERY careful with the hammer, you shouldn't scratch or screw up your rims.
James
matt black
Car: 89 Nissan 240sx ka24de
i had the same problem about 2 months ago... i went to sears and paid 20 dollars and they got them off for me
driftercs13
Car: drifting and nissans
hey don't go pounding on a socket take it to the tire shop most of the time one of the techs will have a reverse bite socket. all they all have to do is just put on the lug and turn it out. i have one and it can save alot of headaches. they make reverse bite sockets for almost all bolts and lugs now. just my thought.
ricebike
2002 Quest
2005 Altima
if it's a very slow leak & u can wait; goto their website, & contact the manufacturers directly to see if they can just give u a replacement key... then compare the costs of getting a new key (if possible) to just starting over w/ new lugs/key set
here, i'll link it 4 ya to quicken the process...
http://www.adrwheels.com/
good luck n keep us updated
edit
http://www.pepboys.com
goto 'tires and wheels'
click on 'wheel & tire'
then 'ADR' link
finally 'caps and valve stems'
i dunno if this is what the tool looks like; u may haveta walk into the store & physically see the catalog that they have stored in the shelf; i remember from working there that they have more pics & the adr site doesn't deal directly w/ customers anyways <shrugs>
bcar240
Car: 1993 240SX HB
thanks for all the help! I took it by a local quickie shop and they were pretty interested in my car. I talked with the guys for a while and they just happen to have an extra key that fit my lugs so they let me have it. The world isn't all bad!
