Katapl »
https://forums.nicoclub.com/katapl-u46973.html
Mon Nov 19, 2007 3:36 pm
So today I recieved Logan76's car from the auto shippers. It started fine, but wanted to bog-out until it was warm. Oh well. Upon getting it home, I realise the oh-so-famous 'high gear i.e. drive in reverse really fast' whine is coming from the transmission in almost all gears. It's out of fluid. I filled it with 2.5 quarts of Synchromesh and ordered MT90 from Jegs.
After changing the oil, the car wouldn't start. The battery was dead, and I have NO IDEA why. I charged it, and noted that only 1 headlight worked total, the HUD didn't work at all, and there were no interior, except for a boost gauge in the dash. If it's accurate at all, it read -20 vacuum at idle.
I also noticed an EXTREMELY high pitched whine coming from what seemed to be around the exhaust side of the engine. I imagine it's what a 500lph fuel pump would sound like. Upon giving it throttle, the whine stops, I believe.
So I put it in reverse and back-out of the driveway. The car was kind of stuttering the whole time. I got it into first, and it was acting completely haywire. I couldn't get it to move at all. In 1st gear, applying the gas, it started to actually bog a little. That was pretty odd. Then it died, and wouldn't start again. I figure this may be attributed to a bad alternator, but I'm not sure.
I could seriously use some help from you guys right now.
