nexus08 »
https://forums.nicoclub.com/nexus08-u218705.html
Sun Dec 22, 2013 5:45 pm
There are lots of things that can cause the car to idle fast. The Z should idle at around 800 rpm when warmed up if all is well. Too high might indicate a problem.
You can check the engine codes to see if any codes are showing. Search here you should be able to find a link that tells you how and what the codes mean. Most of the time, if there is a code, it is because the sensor went out. Some sensor malfunctions will put the car into a limp mode so as to not damage the engine, this can cause the car to run very poorly. Anyway, check that, fix what ever it might indicate. If you have a question about what one of the codes means feel free to ask.
You should check to see if all your fuel injectors are firing. While the car is running, put the base of a long screw driver to your ear, and the other end to the top of each fuel injector. Be carefull not to get anything into the fan while the car is running like your hand or a tie. That could be very bad. You should be able to hear each fuel injector "click" as it fires. No click means that fuel injector isn't firing right.
You can also "ohm" them out by taking the fuel injector clips off and measuring the resistance across the injector. If one is out of specs (don't remember specs off hand, search google or site) you probably need to replace it.
As far as the throttle body, both sides should look nearly exactly the same as you pull on the throttle cable. The should open and close together and to the same degree of openness. You can adjust the throttle bodies if necessary.. search here or google for instructions. You probably shouldn't try to force the throttle body closed by pushing on the butterfly valve as you can bend it fairly easily.
