Cjmartz2k »
https://forums.nicoclub.com/cjmartz2k-u65761.html
Sun Feb 17, 2008 9:55 pm
I know the Poncams only come in 256, I was just saying I want one. The exhaust cam is a HKS 256 anyways, so they are a little mis-matched, but they came in the motor, so I was like "fck-it" and kept them in there. I'll either get a poncam for the intake (and mod the intake mani to get back VCT), or if the HKS intake cam works well, get a HKS 264 ex cam. I think the intake being bigger on a turbo motor is backwards, but hopefully it will still be better than stock cams, even with out the VCT.
The VCT (which I call VVT all the time, but I mean VCT) solenoid on the side of the head hits one of the coolant passages on the RB26 intake manifold that came on the series 1 motor with an adapter. I'll try and get a pick up soon.
I'm not sure about the lobe angle, but I'll ask my car guy tomorrow. Maybe it has something to do with advancing the cam on a RB20 on the top end like a RB25 would do with VCT?
Are you running stock springs? I am, and the lift worries me reference coil bind, but I guess I'll see. I plan on only spinning the motor to around 7.5k, but with the new intake and cams, it might keep making power that high, so maybe I'll want to spin it higher, I dunno. I set the limiter at 8k on the other motor (it had a GTR oil pump), but usually shifted around 7.3-7.4k because it felt like the power was strarting to drop off a little. Probably the stock intake and throttle body.
