new cams
jkm_250x
Car: in the works of obtaing a 240sx with a sr20det swap
if i put new brian crower stage 2 246 cams in a sr20det wut all would have to be replaced changed swaped or modified
480sx
Car: 1996 Pearl White 240sx
Well, to get the most out of the new cams you should get a tune with them. That would either require a SAFC, or some tuning system, and a wideband. Or just a tuning system and a local dyno shop.
You can get away with just swapping in the cams and changing nothing though, you just wouldnt be getting the most out of your engine if you did. So to answer your question, nothing really. You just replace the cams, and drive.
