New cam seal is loose in the bore
tommyR
Car: 2003 Nissan Frontier
2003 Frontier 3.3l VG33e, 142K miles- had a front crank seal failure and oil slung into the timing belt, sprockets etc. Engine was a reman installed about 50K ago by previous owner. Front crank Seal was apparently installed incorrectly and the garter spring was partially outside of the sealing lip for a while. During the repair cam seals were also removed for replacement and it was noted that the LH cam seal was black while the RH was red but otherwise seemed ok. The new RH seal installed as expected and with no issues. The new LH seal was same brand, part number and specs but when inserted over the cam it slid into the bore with no resistance, barely touching the bore. The removed old seal OD measured at 1.924in and the new one at 1.900in.At this point I don't know if I should somehow try to find a different seal that fits tightly or use RTV to try to secure the seal I have. Has anyone seen this condition before and what are your repair suggestions? Thanks for your comments!
Niti QX4
Car: 2004 Nissan Xterra
can you see any part number on the orange seal?
Since it worked for 50K miles, I'd go back with the same.
A hydraulic shop should be able to find a seal that matches if you can't find a number.
tommyR
I found partial numbers on black cam seal, which is the one I need. Looks to be 35 49 6? which must be the seal dimensions in mm. The Orange seal is good for rh cam but too small for lh. Thanks!
FrenchPople
Car: 1993 Ford F-150 XL
2012 Nissan Frontier Pro-4X Crew Cab
Are the new seals OEM or Aftermarket?
tommyR
The new seals were aftermarket and both measured the same dimension-wise. Just installed the larger OD 35x49x6 seal I ordered and it fit as expected. Not all back together yet but I think I'll be ok. Thanks!
