lol how many times have I read one of the forum members ask this question or something very similar when a question like this comes up.biosehnsucht wrote:what MAF are you using ? what injectors ?is the ECU stock ? what spark plugs?
I just like to try getting enough facts in before attempting to armchair diagnose. Besides we've seen a ton of people in the last year or so, trying to run unknown modded ECU's with a variety of injectors / MAF, or stock ECU with bigger injectors..ca18detgabby wrote:
what can you tell us? I mean there is a million components that all can cause issues and then create similar issues you are experiencing.ScottieDoritfto wrote:im not sure i just got the car, i just sorta left the fc3s scene. so im kinda really new to the car. i dont know if the ecu is chipped or not i dont know what maf sensor it is, also i dont know about the injectors. FYI also my first time ever having boost. is there any way to check if there none oem like codes or color codes. etc.
new kinda of engine and car so im completely out of the loop.
I know it is getting a bit crazy, but I guess finding total bone stock CA stuff these days is impossible to find.biosehnsucht wrote:
wouldnt a leak release pressure thus less air is inducted and the same amount of fuel is still being added. thus you would be running rich.biosehnsucht wrote:If anything a leak would run lean at idle, at least until the O2 warmed up, then the ECU could most likely (depending on leak size) compensate... but then once you get into boost, it'll leak the other way and be rich..
He's running rich at idle, so it's probably not that.
OMG! I want I want!biosehnsucht wrote:screw that you want the 33MB one, that one has a section index and isn't missing pages. I think the 25MB one is missing pages. Also, more scrolling since the sections aren't bookmarked.
this is why we are having trouble diagnosing w/o knowing things. white? like a bright white or a cream color?ScottieDoritfto wrote:alright i have a update i talked to the guy that i got the car from and he's saying its the blow off valve, cause there used to be a RFL but now im pretty sure its a no name, so either i could try and respring it or get another one or just get a pipe, and delete it until i can get another one, and see if i notice a difference.
also i checked the injectors and there white color codedand the maf sensor is a pod, i tryed to put up a picture but it wont load my cd
Haha....so true. Sounds like something I would say.dattodude wrote:
**** man, it could be this, it could be that. If you don't know if the car is standard, it's like trying to play baseball on the moon.
