new buy. its a project though. Ive got some prob with engine
chunkyhobo
Car: 1991 240sx s13 hatchback SE
ok. when I start the engine, I have to keep a little gas on it, or it dies on idle. It also taps. Last thing, my spoiler was apparently stolen.? its got alot of rust on those mounts where it was broke off, got any suggestions for what to do on any of these? I could use some help.
dickie
Car: Killer Turtle
welcome to nico!
iacv needs cleaned or you need to adjust your idle speed. look for vacuum leaks as well.
more info is required to help you out. what year is the car? what engine? where is the tap coming from?
chunkyhobo
its a 91, ka24de, and i dont really know where its coming from. Im about to prolly take the engine apart, and get rebuild (160k miles). unless it runs good if i can fix it.
dickie
Car: Killer Turtle
if you dont mind the time and money involved in the rebuild, go for it!
im assuming that because you used the word tapping, its not rod knock. if its the timing chain, you can remove the upper guide, but id really stress replacing the chain and tensioners if it has never been done.
as for idle/hesitation problems, that is probably one of the most common and hard to trace problems with the ka24.
you can check your iacv first, but also look at all the general maintenance and tune-up parts and your engine grounds.
