DrSuess wrote:For the front defroster to be working on most cars, the air conditioner is activated in order to remove moisture. By turning off the air conditioner, you have, in effect both turned of the defroster AND disabled the recirculate function. What is it that you are attempting to do by this unique combination of control settings?
Maybe it's not a bug at all?
actually, not..that's not what I meant.
basically when the unit is on defroster mode, and if you press "AC" to turn off the AC.
the light on the "recycle" turns off as well. so we can assume, it is auto set to "fresh" air coming in. Correct?
BUT!!! when I press the "recycle" button, that's when it turns to "fresh". so that means even when the light was off, it was still on "recycle" not "fresh" air.
