SCREAMING EAGLE »
https://forums.nicoclub.com/screaming-eagle-u213737.html
Mon Dec 31, 2012 4:57 pm
I can get the pics, getting them posted could be another story. I will have a friend who is more comp. savey than me help. Once I see him do it, then I will be good. Mounts in the back will be hard to see under seat rails. pretty simple to make, if you can fab and have material your set. It takes per side-one 17" long piece of 1x1 square heavy wall tube, 2 pcs. of 3/16" flate 2-1/4"x 2" for the back support. drill and tap the heavy wall tube to bolt the seat rail too. The flats weld on the tube on the bottom. hole centers on the flats bolt to the floor. I punched the holes 3/8" to allow for a small amount of play. Drilled and tapped the tube at 1/4" centered on the rails of the seat. You must use the second hole forward from the back end and be carefull about the clearence in order for both seat and mount to have room to bolt down without overlapping each other.
On the front, very simple 2 pcs. of flat bar, 3/16 2"x4" long, punch or drill one hole in each- centered and up 5/8" fron the end. Then bend at 1 1/4" from same end at about 65 to 75 deg. You will have to cope out inside front mount to allow for flat bolt up because of the floor mount in the truck has a small bulge in it.
