New brakes for my vert
Little Danny
Car: Nissan 240sx Convertible
Hey did a z32 front brake swap with drilled an slotted rotors on my vert today and cannot get brake pressure back after bleeding it. it will build pressure when you pump it but if you start the vehicle, the pedal goes back to no pressure there is no leaks anywhere im at a loss any suggestions?
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
I would bleed all four brakes and see what happens. Did you have help bleeding your brakes or did you do it yourself. I think when you do it your supposed to close the bleeder valve when you pull the brake pedal back up
biggie
Also make sure you put the calipers on the correct sides. Bleeder should be at the top of the caliper.
Little Danny
Ive figured it out now it stops amazingly but still have the rears to do .... do i need to have the whole 300zx e brake assembly or is there a way around it?
94_240sx
Car: 94_240SX
Little Danny wrote:Ive figured it out now it stops amazingly but still have the rears to do .... do i need to have the whole 300zx e brake assembly or is there a way around it?
You do need z32 e-brake assembly. Do you still have 4-lug? If so, you will have to find correct hubs with correct anchor bolts. Search my write up.
Little Danny
I do have five lug hubs already .... i have the rear calipers pads and drilled and slotted rotors already ... so i guess i will have to wait till i can get the rear e brake assembly before i do the rears
