SO correct me if I am wrong, but my stock calipers will be for ABS parts.SOOOOOO, the parts I need to get need to be abs right???? NON ABS pads will not work right??tenkawa_akito wrote:I have KVR pads on my 300ZX calipers and they're a good strong performing pad.
As far as ABS goes, the calipers and rotors are slightly larger than non-ABS cars, so you'll want to pair up ABS parts for your car.
Depending on where you get your rotors, cross drililng and slotting don't incur extra charge (heavy throttle for example). And if you're going for pure bling, get them cross drilled and slotted. I hear the kids like 'em that way.
I ended up with drilled and slotted rotors (it was all HT had in stock when I ordered them) and have not had any performance issues on the street. About the only performance issue that crops up from cross drilling is that the rotor is weaker and is more succeptible to heat related problems and cracking. Something you probably won't get hot enough on the street to happen.
Spydy: did someone change your calipers to accept NONABS rotors & pads??spydy wrote:I changed all 4 corners, all nonABS. I'd guess that both you and tenkawa_akito are right, probably because the dumba** dealer told a previous owner that it shouldn't have ABS brake components.
