New brake standards
Q45tech
http://secure.grubbs.com/Brake%20Bulletin.pdf
Notice all the nice mandantory proceedures to achieve 0.001" maximum runout vs the old spec of 0.0028". ITB04-026a 8/16/04
Doubt any of this is done at any aftermarket shop, probably not at dealers either as the allowable times are too constraining
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
what's a ProCut PFM, and what does it do?
PalmerWMD
Car: 2004 350Z
Nice catch.
Fred..:)
Q45tech
On car lathe to mis cut the rotor to match [cancel out] the bent [out of perfectly true/bearings hub.......rust films can be greater than 0.001" which gets multiplied by distnce from hub to rotor edge.
A precison [perfect] rotor runout correction can add an hour each to a brake job.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Wonder if Infiniti noticed that the 300C SRT8 has the 14" 4 piston Brembos in front and the 12" 4 piston Brembos in back?
Time for Infiniti to quit using old pie pans for rotors on their heavier vehicles.
