Is it necessary to machine the rotors when replacing pads?gwoods wrote:I would use white lithium grease instead of silicone.
When I did mine I used a 99 cent paint brush to apply a little white lithium grease to the back of the pads before I put the calipers back on. It makes the difference between squeal and no squeal!
Ah ah ah ah.gwoods wrote:
If you don't turn the rotors the pads life will be cut at least in half.
There is a product called Disc Brake Quiet. Works wonders. Apply it to the back of the pads per the instructions and most squeaking will be eliminated or reduced. They have a spray can version as well, which works well, is easy to apply and the can will probably last longer than your car (I've been using the same can for 5 years on several different cars).Sentientbydesign wrote:Did you use the silicone brake lubricant between the piston and the pad?
That's a huge part in doing your brakes. The little packet only costs a buck. Go invest, if you haven't.
Make sure you do a proper break in with the pads/rotors. For the first 500 miles you shouldn't EVER apply 100% pressure. Frequent pulses between 20% and 50% are advised. You'll have to do a search for pad/rotor break-in for complete directions.
Generally speaking, I would. Even if its just a very minimal amount off the surface. If you are using the same pads, then as long as the rotors don't have any thickness variations or warping, then it will be fine. Just make sure the pad physically seats and gets past the point of green fade for maximum performance.telcoman wrote:
I agree with #1 disagree with #2.Sentientbydesign wrote:
1# He said that if you stick with the same pad, you'll be fine as the material that is embedded in the rotor is the same that is on the pad (as it SHOULD be per our conversation).
2# Turning can be a royal pain in the *** too because some rotors won't take to the pad materials as well once they're turned.
