LaureltheQueen »
https://forums.nicoclub.com/laurelthequeen-u7115.html
Fri May 30, 2003 2:42 pm
If you dont have anyone to help....
Get a glass of brake fluid(fresh) and open the bleeder valve. Affix your little plastic tube to the end, and stick the other end in the cup. get in the car, pump the brakes, and push some of the air you allowed in there out. it will go through the tube, into the fluid and bubble out, when you release the pedal, it will suck in new fluid. Do this a few times for each corner, then check and see if this helps any. if it doesnt, and you have no leaks, then i'd say its a faulty master cylinder.
