Ok, I was helping out a friend yesterday with something else (car was out of commission for a couple months).
Basically, once we got the car running, the brake lights remain on no matter what. I figured this would be the rubber bushing problem, however I took the switch that gets pushed in/out by the brake pedal out and pressed the plastic button in and out by hand - still stayed on.
I disconnect the plug to the switch, still stayed on.
If I take the stop light fuse out - it will turn off - but obviously off forever.
I'm perplexed... every thread that I found that talks about brake lights always on had to do w/ the rubber bushing - from what I've tested, it can't be since I pused it in and out by hand correct?
If it matters - car is 89 240sx manual
