New brake install has squeaking while not braking
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
just upgraded my brakes to EBC sport rotors with Hawk pads on front and back axles. the install was easy on my g37x took about 3 hrs going slow. after twos days of having super smooth and quiet braking. i now notice a squeaking sound from my front breaks when im not braking. its like a squeaky shopping cart type sound when i get above 20 mph. I didnt forget to lub the shims and i wd-40ed all bolts before screwing them in, everything is tight, cant visually see anything loose or rubbing. even though there is a squeak while not braking, the brakes are silky smooth and quiet when im actually braking. so saftey wise i feel great. but the sound is kinda annoying, but only can be heard if the windows are down.
Am i reacting too early to this? could it just be the pads still beading in? :confused:
I was going to give it about 5 more days before i pull the front tires off, cause i suspect/hope its just the pads wearing in.
here are pics of the install
http://www.facebook.com/media/set/?set= ... 7a17df5e01
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
is it possible you over WD-40'd the bolts and it dripped onto the caliper/rotor/pad?
I woudl be willing to bet its just breaking though.
EDIT: could you pleae PM what you replaced on your fog lights? thanks in advance
kmckis1029
I just replaced the bulbs with I think ultra white 6000k bulbs to match the headlights, I wasn't a fan of yellow fogs
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
do you recall where you picked them up and who made them?.
re: your brakes, how about you take the calipers off and remove the pads and then put it all back together. you never know, it may be one of those freak things
kmckis1029
Yeah that's what ima do tomorrow... Sadly I don't have acess to the lift tomorrow... So Ima have to pay a local shop tomorrow to "inspect and adjust" my front brakes.
http://www.luminicsusa.com/
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
kmckis1029 wrote:Yeah that's what ima do tomorrow... Sadly I don't have acess to the lift tomorrow... So Ima have to pay a local shop tomorrow to "inspect and adjust" my front brakes.
good luck bud! hope you get it fixed up
joe603
Car: 2014 Durango R/T
A lift huh...you wouldn't be talking about the AUTO hobby shop on base would you :)
That's one benefit I do miss...
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
ohh nice perk
joe603
Did you fix it?
kmckis1029
i adjusted all shims and brackets on my front brakes. (sound was limited to the front brakes)
its been about 2.5 weeks and the sound has reduced to mostly wind noise. there is still a noticable sound if im close to a wall on the highway, or if a car passes by close. So its looking like it was mostly break in noise. I did know i was going to get a little more wind noise with slotted brakes. The sound is to the point where if the windows are up i cant heard it at all any more. i Hope it continues to reduce.
and yes Joe i have base access :)
kmckis1029
called up EBC and they said their rotors have a 2000 mile break in period. I have about 2k miles on the brakes now and the wind noise has reduced to a point where its not annoying. I really only notice the sound of the rotors when im close to a wall on the highway. I cant hear the sound with the windows up at all.
Stopping power is great though. It's a definite upgrade from the stock brakes. but next time i buy rotors, unless EBC addresses the wind noise, i will be buying another brand. :yesnod
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
kmckis1029 wrote:called up EBC and they said their rotors have a 2000 mile break in period. I have about 2k miles on the brakes now and the wind noise has reduced to a point where its not annoying. I really only notice the sound of the rotors when im close to a wall on the highway. I cant hear the sound with the windows up at all.
well that makes sense. glad to hear it...
i had ZERO issues with my StopTechs. I cannt wait to get them onthe rear as well.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
