Two Fowty »
https://forums.nicoclub.com/two-fowty-u120229.html
Thu Nov 26, 2009 8:14 pm
Installed a good brake booster and cylinder today into my car. I took them off of my other 240, which I had bought them for., meaning they were used, but still good. I installed them as one; I didn't take the cylinder off the booster when I did it.
Anyways, installed it all, started car up, and there is a sucking/blowing noise, can't tell which. It is coming from where my brake booster comes into the car, like if you get up under the dash inside the car, that's where the noise is. When I press the brake pedal all the way down, the noise stops, and my rpms drop down to like 5-6k and stay there, and my lights dim slightly. When I let off the brake, my rpms go back up, and my lights brighten up, and the noise comes back.
I reached up under the dash and tried to feel any air movement. I couldn't really feel anything. But I moved, with my hands, the rubber covering that is around the part of the brake booster that comes in under the dash, and I could hear a change in the noise, so it was affecting something. I don't really know what it is. It was dark by that time so I couldnt mess with it.
Getting ideas for when I go to fix it tomorrow. Anything?
Also, that little annoying pin you have to deal with when changing the booster, had fallen out when I went down there and looked at it. I don't think that would cause that problem, but just letting you know incase.
