1. I followed pbr's recommendations for bedding in the pads. you do 10 slow stops from 30-40 mph with 20-30 sec imbetween stops. Then you let everything sit overnight and you should be done. When I first started out the pedal pulsed alot, felt rough, and required alot of pedal pressure to stop. I am pretty sure this is normal for fresh pads.
So I followed the bedding in precedure, the feel of braking was a bit better, but not much. i felt the calipers afterwards, and they were barely warm. outside at night (when i was bedding the pads in) its been like 30-40 degrees, so its pretty damn cold.
the next day i did some normal driving and then a few moderate stops from 60-65mph. it seemed to help more then when I did the bed-in proceedure. but there is still a slight pulse in the pedal and the pads sound alittle noisy (rough). outside temp was about 55 degrees.
My intuition is telling me I'm just not getting the brakes hot enough to bed in properly, since i can always touch the caliper afterwards, but maybe im wrong. Maybe this is normal behavior, and it just takes awhile to break them in? The PBR break in guide says to go easy on them for the first 150 miles of use, is this brake behavior going to get progressively better and be completely gone by 150 miles?
2. It seems like the brakes work alot better at highway speeds then speeds under 20 mph (with the same applied force). Im assuming this is just the nature of semi-metalic pads or is it cause of a problem that I might have mentioned in #1? My old pads behaved almost in reverse to how these are behaving :dunce.
**If you have any "new pads n rotors tips" please feel free to share
THANKS!
