New Borla exhaust
All things Altima Coupe.
andyhenault
Car: 2012 Altima Coupe 3.5SR-Borla axel-back, full LED lighting
2010 Altima Coupe 3.5SR-Wrecked
New Borla exhaust and a fresh wash. Spring is here! Anyone else have problems with the tip alignment of the Borla? I found that the right tip sat about 3/4" lower. I shimmed it, but I want to find a better fix.
funkee
Car: '08 Altima Coupe 3.5 SE
I had the same problem.
Raising the right tip is very difficult to do. We tried for a while, but bending the steel hangar to raise it wasn't going to happen. You're better off lowering the left tip instead. Unfortunately my shop guy did it without me, and I didn't follow up to ask how.
SEismyG
Car: 2008 Nissan Altima Coupe 3.5se, Fully Loaded
Enjoying the sound? Pair it up with the Y-Pipe and get ready for an ear orgasm :D and yea I too had the same problem but mine was all lopsided before I even installed the borla...probably gonna put some bolt or something under it and see how that goes...
schleter12
Car: 2008 Altima Coupe 3.5
funkee wrote:I had the same problem.
I was definitely thinking the borla and thanks for the input guys! and "funkee" I absolutely love your tail lights.
Irvxing
Car: 2011 Altima Coupe 2.5s M/T
Check if the flanges line up perfectly.
funkee
Thank you. The turn signals are white and extremely bright with the clear housing. If I'm at a stop light at night, I will literally blind the person behind me. Though it's very helpful on the highways when I'm changing lanes.
