duncan351 wrote:With AF's in the 12's even with a JWT tune I would anticipate a new engine REAL soon. It will blow up pretty quick at that boost level on stock motor. Get those Af's down to mid 11's and pull a degree or two of timing to stay on the safe side. You're o the ragged edge on pump gas with stock compression. Motor should then last a nice long time.
I like the low to mid 12's...more power and more efficient. With timing retard you shouldn't need to run in the 11's IMO. Granted, you can never run anything less then 93, but I still think the mid 11's are to rich. JWT usually pulls to much timing if anything.
THIS IS MY OPINION. I have a knock meter, wideband and experience tuning. So I would run 12's AFR on my car. This isn't for everyone, I'm just stating an opinion.
WD
