The FXT was a good bike in its day, but it's heavy and the frame design around the rear suspension means it fits more like an 18'' frame...which is not good when you're 6'4''. I've been running a very long seat tube to compensate, but that just creates new problems; particularly putting lots of leverage on the rear suspension, which I've had to virtually lock to keep from losing too much crank energy--effectively rendering the whole mess a lot of dead weight. The front shocks have also seen better days and don't really dampen so much as shudder and jolt, plus you've got to flip the bike over and pull out an allen key to adjust them.
The Zed is a nice change, from a bike that's really too small to one that has enough saddle adjust to fit someone even taller than myself. There are a few upgrades I've added to the KHS over the years that I'll transfer to the K2, but for the most part it's a solid all-around upgrade. I'd like to step up to Deore shift spec eventually, but for now the bike will do just fine. It has Hayes mechanical disc brakes, Rock Shox Dart front fork (with preload adjustable on the fly) and basic Shimano shift spec right now.
Here's a nice stock photo of the model:
